Clearance V1 $1.99 while supplies last. These are compatible with all the qs8 connectors on the market, including our V3 versionOSE 8mm Anti Spark Female Connector System. Available in Black or Blue Housing. Anyone who's ever powered up an 8s or higher power system knows the dreaded spark that scares us all to death and at the same time ruins the connector. This gold-plated bullet connector has an anti-spark housing that will reduce this spark to almost nothing. These are a must for high current/high voltage brushless power systems. Sold as a single Female connectorIncludes: (1) Female Antispark connector (1) Wire Cover Options:Black or Blue Housing Specs: Bullet Diameter: 8.00mm Metal Material: Gold Plated Brass Plastic Material: Nylon with fiber. Flame retardant rating: UL94 V2 Temperature Range: -20C to +100C Weight: 20 grams Length: 38mm including wire cover.Width: 27mm Max Wire: 6AWG
