Castle Creations Capacitor Pack 8S (5v-35v)
Recommended for up to 8s Maximum.
It is generally reported that capacitor failures can be attributed to: 1) Heating, causing a capacitor to swell and explode. 2) Drying of the liquid electrolytic inside from various causes, such as defects, leaking and even cleaning. 3) Capacitors re-form over time to meet a usual and expected voltage. Surges that are not normal can cause sudden failure. 4) The older they get the greater the incidence of failure.5)High-current motor setup will tend to kill the caps quickly (because of the large voltage changes).
WARNING: If any capacitors seem to bulge, start to deform, leak or pop, stop using them IMMEDIATELY!!! If Capacitors fail they can explode and cause injury. Third picture shows a typical installation. ESC NOT included!!
