Dynamite LED Program Card Unlock the potential of your Dynamite Brushless ESC with the Dynamite LED Program Card. You can quickly and easily set the programming parameters on a varity of Dynamite Fuse car and truck along with marine ESCs. The LED Program card comes with everything you'll need to connect to your ESC including a Mini-JST Adapter Cord and Servo Adapter Cord Features:Compatible with DYN4850, DYN4940, DYNS2416, DYNM3875, DYN4955, DYNM3876, DYNM3865 and DYNS2641 Dynamite Brushless ESCs and Hobby Wing Seaking ESC's
Allows for quick and easy programing without needing to use the transmitter. Programs the following parameters on ProBoat ESC 120A BL Marine ESC 2-6S (DYNM3875) 1)Forward/Forward & Reverse. 2)Number of cells(Auto or Select your own Cell Count) 3)Low Voltage Cutoff, Program Cutoff Voltage (No Cutoff, 2.8, 3.0v, 3.2v, 3.4v)4)Timing (0.0, 3.75, 7.5, 11.25, 15.0, 18.25, 22.0, 26.25
Includes: (1) Program Card(1) adapter wire for programing a Version 3 Seaking or Leopard V3 esc.
