EC5 Battery Harness for use with 2 esc's and 2 batteries. In twin motor applications where you are turning laps around a course. Generally one motor will draw more than the other from the pack, Using this harness will run the esc's in parallel, so they will drain both batteries at the same rate. Using this will allow use of two batteries with the same ESC's. Doubling the voltage to your esc/motor.
What makes the OSE gold bullet connectors different than the other lesser expensive connectors on the market? We order our connectors with a gold plating that is much thicker than our overseas competitors. This increases the cost, but makes the gold plating last longer while also reducing resistance.Includes:Everything in the picture.Note: Using this will double the battery voltage of the system its used in. You must use two battery packs of the same exact specifications, age and quality. Failure to due so could cause a fire.
