Adjustable 56mm Motor Mount. This works well in a deep vee / mono style hull. Now features Carbon fiber stands with glue holes in the mount which adds extra surface area to improve mounting.
Fits: Motors that are 56mm diameter x 80mm or longer.ExamplesLeopard 56mm motors, 5692, 5692 and 56110TP Power v1 motors, Tp5660, TP5670 and TP5680TFL-SSS 56mm Motors The integrated top plate can be used to mount an esc. All Aluminum construction. Note: If mounted in a flat bottom hull, this will require mounting blocks to lift the mount. Works with up to a 70mm long water jacket.Install Note: Center metal section measures 4" wide, so if needed the center two metal parts can be used in hulls that have 4" wide rails.
