OSE Parallel Harness with 10 gauge wire for use with EC8 bullet connectors. Using this will allow the use of two batteries to double the system MAH but the voltage will be the same.
What makes the OSE gold bullet connectors different than the other lesser expensive connectors on the market? We order our connectors with a gold plating that is much thicker than our overseas competitors. This increases the cost but makes the gold plating last longer while also reducing resistance. Includes:Everything in the picture.8 Gauge Wire soldered to the EC8 connectors. Note:Because runtime is doubled, it's important to monitor heat buildup in the motor, ESC, and batteries. You must use two battery packs of the same exact specifications, age, and quality. Failure to do so could cause a fire.
